Wedding Invite - need some help!
I was wondering if anyone knows of an SVG file of an invite like this with the flaps.
- Roco Letterpress Wedding Invitation Unique Envelope Design.jpg (141.91 KiB) Viewed 10917 times
Re: Wedding Invite
Sorry, but don't see any attachments/photos or links.
Re: Wedding Invite
It should be up now. Any help would be appreciated! Thanks!
Re: Wedding Invite - need some help!
btt...sorry the approvals as a new member have been slowing this for you.
Will this help..
There is the flap shape, a rectangle for the fold lines and a rectangle for the actual invite.
This is for an American A2 size card, if you want one for a specific size of invite just let me know the size of the printed invite card part and I will make one for you
Wow, you are the best, I would love one that is 5x7 but I have SCAL2, not sure if you can save it as that!
Thanks so much!
Thanks so much!
I can't, but I can save it as SVG which you can import into SCAL2rmcleish wrote:Wow, you are the best, I would love one that is 5x7 but I have SCAL2, not sure if you can save it as that!
Thanks so much!
Give me a few mins and I will upload for you
OK, here is a 5 x 7 version in SVG to import into SCAL.
Please note the SVG needs to be rotated 45 degrees to fit on a 12 x 12 card - it is a shade under 9.5 x 9.5 inches then. I have already rotated it in the SCAL3 version.
I have not included the 5 x 7 rectangle, I figure that will be easy enough to make anyway LOL
As with previous, red is cut lines, pink is score lines if you wish to score with the cutter instead of by hand.
***EDIT*** There was an error, correct versions posted later in thread..
Last edited by Louise-Paisley on Sun Jul 01, 2012 9:39 am, edited 2 times in total.
if you prefer here is a version with rounded points, might look a little nicer when folded..
***EDIT*** there was an error in the files, correct version posted later in the thread..
Last edited by Louise-Paisley on Sun Jul 01, 2012 9:40 am, edited 1 time in total.
