This is a pretty detailed cut, not sure what the min size will be, I have it on my wall at about 28 x 28"
This is a single graphic..
And this is a split graphic for cutting in two halves..
Loula Cat Head SVG for vilyl cutting mostly
Re: Loula Cat Head SVG for vilyl cutting mostly
Thank you for all of your cat files. My cousin is a crazy cat lady and will love these on things!
Ahhh...what a cute face on this one!
Louise, this is an outstandingly beautiful file. I can only imagine how long it takes to cut but well worth it for the benefit of having it.
Thanks for sharing this and the others.
The one I cut for my wall was done on my 15" cougar before I got the 24". I cut it in two halves, top half and bottom half, to get it 28" square(ish)papasue wrote:Louise, this is an outstandingly beautiful file. I can only imagine how long it takes to cut but well worth it for the benefit of having it.
Most large vinyl cuts I cut at 500mm/sec so it did not take very long at all, it is small detailed cuts that take longer because I have to drop the speed right down to 50mm/sec or less so the bits are not pulled up.
The most detailed I ever cut was 55,000 nodes, that one took quite a while LOL
I made this T shirt for my granddaughter.Thank you so much for a lovely file.
- phpg8PwXzPM.jpg (32.26 KiB) Viewed 11629 times
Windows 10 Scal 2 and 4. Black Cat Cougar
WOW that is fantastic! what a great idea, I have tee shirt vinyl to cobble dogs with and have never actually made a single tee shirt yet LOLOL
Thank you, Ingegard, for posting your project...It is AMAZING!
WOW!
jane
Creativity is a continual surprise.--Ray Bradbury
Silver Bullet 13, SCAL 4.038, Win7 64 bit
