NO popdots- PTPULLEY butterfly border corrected file updated
PTPULLEY butterfly border page 2.
Re: NO popdots needed
removed
ptpulley
Post by ptpulley »
Thanks for the butterfly cut. I like it. I found this image someplace a while ago (no idea where), and saved it because I thought it might be a nice border to recreate sometime. I don't think they used your butterfly cut technique, but it would be a perfect use for it.
I use a BabyBug, SCAL2.
That might actually be a punch...but we have had similar borders done here, and the idea for lifting the image in 2 cuts probably is not new by me...but it is new 'for' me...so anyway thanks...glad you like it.
We have a lot of new members and so this will be like new for those who have not seen all that has come before.
What I would like are more ideas for half cuts...like what shapes would be good for the tuck designs or like petals for flowers that would lift up...I just like it so it is going to be my focus for a while...hee hee.
If anyone else makes some stuff like this or with these little helpers I gave....please show the ideas or projects.
ptpulley
Post by ptpulley »
Did you say that you do the single line cuts in Inkscape? I have worked with Inkscape a bit and find that I am much more comfortable with SCAL. I have no idea how to use the drawing tool in SCAL-- I just mess up everything I try to do with it. Any suggestions for a place to learn how to use it?
http://www.youtube.com/watch?v=eZCVneME ... Pc5xsIl4dV
This is one of the places I learned(I learned most of what I know from Kay and the Scal tutorials here on our homepage)...short bit about the pen tool at the end. Plus in our tutorials you will find some on the CE homepage. Maybe others can direct you also.
Basically, if you left click and drag and adjust handles you can get arches out of the straight lines, or you can left click and release and move to the next spot and click to try to create your arches node by node and then find the handles to adjust.
I am not that good with any drawing tool except sometimes I get lucky, or just use straight lines mostly.
I start the single line cuts in SCAL...to first do a copy and paste in place and a shadow of one and make it .50 or smaller and then a front minus back and then break the image in half by laying a rectangle over half and doing back minus front...they are just scal library images...then I was using paint to erase the ends...and then going to ink(I am not real good with ink), but I don't need to do the paint part I realized. I just export the half image from scal as an .svg and take into ink and break path, click on nodes and then the break path node button at the top left, then select all and ungroup and pull the lines apart....something like that...it takes me several and many more tries to get it.
Sorry that I can not explain better what I do.
I think I have the butterfly border file here.. I had done that for a member here a while back.. I think it was before your time.. But great job gj1
removed.
Ptpulley...one thing I do know about the pen tool and nodes is that sometimes it is difficult to grab and move...they have to turn blue...but if I ungroup and hide the thing right next to what I what to work with...then I can do it.
I am going to try to work with it more and see if I can come up with line cut straight from scal...because as I said, I had trouble with the one used in this flower. The heart and butterfly worked good though and I could never make either of those with a line tool...but maybe little arches and such to stretch for flower, or the half squares for squares and diamonds. If made in scal they would cut right. I am most comfortable working in SCAL also and LOVE LOVE love my SCAL!!!
removed.
