Page 1 of 2
SCAL and Inkscape - A marriage made in heaven
Posted: Mon Feb 25, 2008 2:27 pm
by AnointedHands
Welding is possible when using Inkscape....thanks SJ5. I didn't even know about the program. I had an older version of CorelDraw and was trying to do some things with that and decided that I am going to have to upgrade. Once I found out about Inkscape, downloaded it and love it.
I have attached a file created with Inkscape and SCAL.
- HomeSweetHome.JPG (73.38 KiB) Viewed 8001 times
Re: SCAL and Inkscape - A marriage made in heaven
Posted: Mon Feb 25, 2008 3:02 pm
by susan
That is fantastic
did you create it in coral draw?
Posted: Mon Feb 25, 2008 3:14 pm
by AnointedHands
This was created in Inkscape which is the same type of program as CorelDraw, only freeware. I have version 8 and I could not figure out how to save as .svg using Corel. Inkscape is an excellent program. If you can use CorelDraw, you can use this program.
Posted: Mon Feb 25, 2008 3:36 pm
by boysboysboys
Is inkscape difficult to use??
Your design is great by the way!!!
Posted: Mon Feb 25, 2008 3:57 pm
by AnointedHands
boysboysboys wrote:Is inkscape difficult to use??
I have used CorelDraw for years, so it isn't for me. If you are not familiar with vector-based artwork, it has a STEEP learning curve. However, once you get the hang of it, it is a breeze.
Posted: Mon Feb 25, 2008 4:03 pm
by boysboysboys
Hmmmm STEEP learning curve....sounds hard! I may try it anyway!! Wish SCA could weld!
Posted: Mon Feb 25, 2008 4:20 pm
by AnointedHands
boysboysboys wrote:Hmmmm STEEP learning curve....sounds hard! I may try it anyway!! Wish SCA could weld!
Here is a post with instruction on how to weld the words together. I welded my words inside another character so it was a bit more complicated cuz I had to so some manipulating...that the steep learning curve part.
Check this post out.
http://forums.surecutsalot.com/viewtopic.php?f=6&t=68
Posted: Mon Feb 25, 2008 4:32 pm
by lisa_anderson77
I am new to this board so hello everyone! I have downloaded inkscape today and it came with soooooo many files that were unzipped I am having trouble finding the install or setup file. Can someone point me in the right direction.
Posted: Mon Feb 25, 2008 4:46 pm
by AnointedHands
lisa_anderson77 wrote:I am new to this board so hello everyone! I have downloaded inkscape today and it came with soooooo many files that were unzipped I am having trouble finding the install or setup file. Can someone point me in the right direction.
when you download the file for the program, I think it gives you the option to "run" or "save". Just choose run and the program will install.
Posted: Mon Feb 25, 2008 5:41 pm
by Kate
That is really cool! Thanks for the heads up on installing inkscape- I am just downloading it now and I think I will cancel and run insted of save! Thanks!
