Is there a way to Save SCAL2 ...
Posted: Fri Jan 08, 2010 11:45 am
by jamie Lane
Hi, I am still new (I can use that for a while, right?!)...
Is there a way to save SCAL2 projects so SCAL users can use them?
Jamie
Re: Is there a way to Save SCAL2 ...
Posted: Fri Jan 08, 2010 3:46 pm
by gingerd
I'm guessing no. Why? Because the ending of a file comes from the application where it has been created. You can try deleting the "2" on the end of a file, but I don't have luck with that.
An old application can't read an updated version's files. The old version doesn't have all the info that a new version has.
If you keep the file as an SVG then I they should be able to put it into whatever SCAL they have.
HTH,
Ginger
Posted: Fri Jan 08, 2010 4:40 pm
by Sweetness4713
When you import your svg to SCAL and save it , it automatically saves to .SCUT ....
Posted: Fri Jan 08, 2010 9:16 pm
by sboz
Sweetness4713 wrote:When you import your svg to SCAL and save it , it automatically saves to .SCUT ....
Umm.. Yes but no. Your .svg file(s) still remain on your computer as a .svg file but the page 'design' you 'create' using your .svg files with SCAL are saved as either .scut (if you have version 1) or .scut2 (if you have version 2).
Shari
