moving lines
Posted: Sun Jan 03, 2010 11:53 pm
by ladypj
I wonder if anybody can help with this problem.see images converted in inkscape of showboat which when put into scal some of the lines move i have tried ungrouping the file but to no avail
Re: moving lines
Posted: Mon Jan 04, 2010 2:22 am
by Craigg64
HI
When I have had that happen to me I open the svg in inkscape. Select all the image and copy it to the clip board.
Then I open a new inkscape page from the File - New menu. Then paste the copied image into it. Save it and cut that file. It should work. This method worked on this file for me.
Why??? Who knows
Some times the svg file gets corrupted for some reason and copy and pasting it to a new file seems to corrected it
Hope that helps
Cheers
Craig
Re: moving lines
Posted: Mon Jan 04, 2010 5:03 am
I would guess that you are using Inkscape 0.47. Try using Path/Union on your trace. That should take care of it.
Re: moving lines
Posted: Mon Jan 04, 2010 8:57 am
by jasenj1
Also try the paint bucket tool. I've found that it will "fill in" a complex shape with a continuous path object. This works nicely when I build an image up from multiple pieces. As long as they are all the same color (or within the tolerances set in the paint bucket) I can get a single continuous path quickly.
- Jasen.
Re: moving lines
Posted: Sat Jan 09, 2010 11:38 pm
by ladypj
Thanks to you all or the replies which sorted the problem out for me. However when i import the image into inkscape the windows become rounded and not square?
Re: moving lines
Posted: Sun Jan 10, 2010 12:57 am
by Craigg64
Unfortunately the tracing process is not accurate.
You can play with the svg in Inkscape to fix up any problems.
Tracing works best with large images with nice sharp/crisp edges. As soon as the lines start to get fuzzy they will not give you a perfect trace.
Cheers
Craig
