what kind a paper works best for boxes?
shesteasing
Post by shesteasing »
the decorative paper I have seems way too thin to make a box. what is recommended?
Tingha Treasures
Re: what kind a paper works best for boxes?
Post by Tingha Treasures »
Hi
I use double sided papers and printed cardstock.
swirliepants
Post by swirliepants »
I use cardstock for all of my boxes. Some cardstock brands are thinner than others so just check it out. I get most of mine at JoAnne's and the DCWV paper stacks are awesome and full of colors
momof3
Post by momof3 »
where did you find your box template? :)
lkc
Post by lkc »
I have also spray glued a favorite decorative paper or wrapping paper to cardstock to cut. That's what I did for these little bags...I had some beautiful rose gift wrapping paper and wanted to use it.
Laura
Tingha Treasures
Plenty of files in the svg section :-)
shesteasing
actually it turned out to be the box file i was using. it was poorly designed. i used the double sided paper from Costco and changed the box file and they came out cute. i wanted to make 4" square by 3 1/2" tall boxes with lids to put 4 chocolate chips cookies in. i'll cut the freezer paper for the inside and they will work perfectly!
Thanks, Lynn
boxes photo
boxes photo
Tingha Treasures
Oh they are really nice, love the way they have turned out.
:D
btails
Post by btails »
really nice boxes !!! are you interested in sharing the file for them ??
shesteasing
Thanks. Of course, here they are. The box top is slightly bigger than 4" and you'll want to move the window over if you want a window. I also added a name to cut out. Once the box top was cut, I cut a 4" square of clear plastic film using scrapbook acid free protecting sheets and glued it inside the lid so the cookies will stay fresh.
These are the first files I have made so they are probably very rough compared to others.
4inchboxtopwithfloralborder.scut
(145.49 KiB) Downloaded 238 times
4inchbox.scut
(5.79 KiB) Downloaded 262 times
