I've been trying to follow Susan's and Dan's tutorials on Inkscape, but have hit a problem. The "fill" doesn't seem to work. It looks like Dan selects an object, then just chooses a color from the color blocks at the bottom and the object just magically fills. Mine doesn't.
Can anybody figure it out? If I did this correctly, there should be a screen shot. Thanks.
Evelyn
Fill doesn't seem to work
- WontFill.tiff (140.94 KiB) Viewed 1195 times
Re: Fill doesn't seem to work
You need to choose view "normal". You wont be able to see the color fill if you are in view "outline". Hope this helps
Grammy
Grammy
You're BRILLIANT!! Thank you, Grammy
Evelyn
Evelyn
