eCal constantly crashes when adding text to path
Posted: Sat Jun 02, 2012 4:29 pm
by jax3cats
I am a newbie to this software but am very familiar with several other cutting programs and am comfortable with how things are SUPPOSED to work.
I am adding a circle to my mat, then trying to wrap my text to the circle. I select my font, resize it to the right height, and click on the path. As soon as I start typing, eCal crashes and shuts down.
I was able to do this one time successfully, but on the next 5 attempts (with a computer reboot after the 4th time) the software continues to crash
I am running Windows 7 64bit with an intel Core i5 processor and 6GB RAM. I don't have any other programs open concurrently and am confident my computer is capable of handling this seemingly simple process.
I just installed the eCal update today. Is it possible that's causing the problem?
This is getting really frustrating!
Re: eCal constantly crashes when adding text to path
Posted: Sat Jun 02, 2012 5:21 pm
by gj1
You should contact support with the form...they will get back to you quite quickly. This operation should not be causing anything to crash. I am sorry you are having trouble.
Posted: Sat Jun 02, 2012 6:23 pm
by sstehman
It is possible the update will solve it, however, I have experienced that when I close eCAL and then restart it the crashes tends to continue.
If I shut restart my computer and restart the cutter, it resolves the issue.
Posted: Sat Jun 02, 2012 10:21 pm
by ScrappyKat
I am having a similiar problem as Jax3cats. I entered my name in a fancy font (most recently Scriptina) and tried to "convert text to Outline" and it crashed my ECAL. It happened 2 out of three times. The middle time when it did not close, I used a clean, simple font, Arial. The first time I was using Inspiration, so it isn't a problem with the one font. I did restart my computer after the first time. My my laptop has the same features as Jax3cats.
Oh yeah, I just updated early this morning!
Posted: Sun Jun 03, 2012 6:51 am
My mac and ecal 1.004 is working perfectly on text to path, I did it several times with the circle and different fonts with no problem. Must be another WIN thing. Send an email to
support@craftedge.com.
Posted: Sun Jun 03, 2012 5:18 pm
by jax3cats
I have come to the conclusion that this is just very buggy, prone-to-crashing software. I was finally able to come up with a workaround for the text to path issue; I have to make sure my object/path is HUGE when I create it and then resize it to the size I actually need once it's done. Not a big deal, but just one more senseless extra step.
I am not working on any elaborate or node-intensive projects, but it seems at every turn I get a "not responding" error. Today it took at least 2 full minutes to join 8 2-inch scalloped circles with the layer below it to create a solid shape using the "union" function. I started doing one at a time then realized I could speed things up by doing two at a time. Nope, system stopped responding, presumably while it "processed". Then I decided to see what would happen when I did 4 at a time. I had plenty of time to go to the bathroom and get a drink of water before it "responded".
I use processor-intensive programs like Photoshop and don't have a bit of trouble, but it seems every time I open eCal I am repeatedly restarting because it crashes. I am really starting to rethink my purchase of the eClips because of this poor excuse for software.
Posted: Mon Jun 04, 2012 2:04 am
by sstehman
It would be helpful if you can send a report to CraftEdge and even the file that is crashing for you. If you would like to send it to me too, I will send you my email in a PM so you can forward what you are working with.
