Page 1 of 2
Projects end up with cut lines using trial version of CDS
Posted: Sat Nov 08, 2008 4:11 pm
by scrappingmad
I have tried to cut three projects I have used succesfully before - baby cribs but this time they are cutting with lines through them. I haven't used the little bug for a couple of weeks and was asked to update firmware which I did. I received this update message previously but each time the firmware remains at 1.01. I only have the CDS trial version but never had a problem before.
I have read through previous posts but these seem to relate to cutting letters or fonts or are inkscape related. I am desperately trying to make a gift for a friend whi has just had a new baby so any help appreciated.
I would roll back to a previous version if I could find out how to - previous was 1.01 and that's what I still have.
Thanks for any help you can give
Re: Projects end up with cut lines using trial version
Posted: Sat Nov 08, 2008 5:28 pm
by raewyn64
The trial version has always had a "watermark" feature in it where it cuts 3 lines through every image you cut out - so that you can test it but can't use it fully until you pay for it.
I am not sure how you managed it before but that would seem to be what your problem is - that you are using the trial version.
Raewyn
Posted: Sat Nov 08, 2008 7:20 pm
by He**inwa
If you still are using the same CDS trial to update, your firmware will stay the same.
Did you update SCAL to the latest version-- is that the previous version 1.01 that you are referring to?
Posted: Sun Nov 09, 2008 1:40 am
by scrappingmad
I know that the SCAL trial version cuts lines through projects but this is the CDS trial version that I have never encountered any problems with. I am trying to cut an old Cricut project I have previously cut 2 or 3 times. My version of SCAL is 1.011 as I never felt I needed to update until all the problems with compatibility were resolved.
If the firmware doesn't update on the trial version of CDS why do I get the message to update and it then does nothing?
Re: Projects end up with cut lines using trial version of CDS
Posted: Sun Nov 09, 2008 8:01 am
by He**inwa
Just a thought:
Have you unistalled and reinstalled SCAL?
If so, you need a new activation code, otherwise it will function as a trial version.
If not, then need clarification:
When you turn your bug on, what version firmware does it say on the screen on the bug itself?
[The firmware version number is not the same actual number as the version of CDS or SCAL]
What program asked you to update firmware on the bug?
Posted: Sun Nov 09, 2008 11:12 am
by scrappingmad
No, have not done anything with SCAL. I was only working with the expression and the trial version of CDS. The expression displays 1.01 and so does the CDS trial version. This has never happened before.
I have just now updated SCAL but don't know whether that will make any difference at all.
No it hasn't made any difference - still a cut through another design.
Posted: Sun Nov 09, 2008 11:44 am
by He**inwa
That is a bit odd to me.
I've seen the expression itself say v 1.1 , 1. 3, etc but never 2 numbers after the decimal.
Just to clarify, the file you were trying to cut, were you cutting it in SCAL or in CDS ?
Posted: Sun Nov 09, 2008 12:21 pm
by scrappingmad
My error the expression has v1.1 and CDS has 1.011.
I have now uninstalled CDS and reinstalled which seems to have cured the problem but I have now noticed that after the SCAL update the cutting is soooo slow - I think I saw another post on this. I will have to keep my fingers crossed that my project will now cut properly.
Posted: Sun Nov 09, 2008 12:51 pm
by He**inwa
I did see some posts on this, but then I saw mention that the 1.015 version download on the home page here is actually 1.016 and that it seemed to cut faster.
I haven't seen a significant difference, but I usually cut slow anyway.
Glad it seems to be working now--Hope it still is.
Posted: Sun Nov 09, 2008 12:52 pm
by scrappingmad
Don't believe it - just cut the crib again and 2 cuts in crucial places. Help - I have no idea what to do next - thought the uninstall would resolve the problem.
