pumkin faces
Posted: Tue Oct 04, 2011 6:31 am
by mommylala1
I am looking for some cute faces for pumpkins.. but not really jackolatern faces... more like the instant message type faces.. does any one have any to share? Im not good at inkscape.
Re: pumkin faces
Posted: Tue Oct 04, 2011 7:16 am
There are about a gazillion here to choose from. Emoticons they are called if they are the type you are looking for.,
http://www.google.com/search?client=saf ... 04&bih=744
Re: pumkin faces
Posted: Tue Oct 04, 2011 3:07 pm
by mommylala1
kinda like thos but how do you turn them into an SVG? I dont know inkscape
Re: pumkin faces
Posted: Tue Oct 04, 2011 5:51 pm
If you have SCAl2 or 3 you do not need Inkscape.
*Select image from the top menu and import/trace it into SCAL, the image you already has works fine.
*It will all be in one piece so you will need to do an object/ungroup (I had to do it twice to get it all ungrouped).
*With the select tool draw a box around one of the images you want selecting all the pieces in that face. Do a object/merge. This regroups/merges all the pieces of that image back together.
*Continue until you have all the faces you want to use merged individually
*Save the file under a different name, it will save as .scut This is your scal cutting file.
*Now you can delete all the faces you don't want and save again.
*You now just move the images around to fit your paper and cut away!
If you need more just let us know and we will help you through it.,
Now you can delete
Re: pumkin faces
Posted: Sat Oct 08, 2011 8:55 am
by mommylala1
Thank you.. I think ive got it.. the eyelash ones didnt work real well but most the others did. Can I ask the difference between the Merge and Group option in SCAL?
Re: pumkin faces
Posted: Sat Oct 08, 2011 11:04 am
by Sweetness4713
Merge every part of an item join as one... Like union. .Group is the pieces go together but you can separate them by ungrouping..
Re: pumkin faces
Posted: Sat Oct 08, 2011 3:58 pm
by firstcut
