Eyes!
Posted: Sun Sep 21, 2008 7:45 am
I think these are great eyes! The blue has 3 layers - choose as many layers as you wish starting from the largest in. Eye whites are in green so you can see them. Unfortunately, the black lines above and below the eye are only lines and will not cut as a shape. Use them as guides to draw or remove them. The eyelashes, eyebrows and lines under the pupil will cut. Highlights in eyes are in pink so you can see them. Change colors as desired. Re-arrange SVG contents as desired. Some pieces are grouped together so they can be moved easily. To ungroup in InkScape, select all, click Objects -> Ungroup.
Please post what you do with this if you use it - I'd love to see!
