inkscape to scal
Posted: Fri Mar 25, 2011 2:15 pm
by hellma
Can anyone tell me of how to set up Scal so that when you import a file made in inkscape, it imports at the same size. Not even sure if this can be done but I am sure I seen it somewhere.
Thanks for any advice
Re: inkscape to scal
Posted: Fri Mar 25, 2011 5:44 pm
by Sweetness4713
If you look up at the dimensions of your project in Inkscape there is a lock you can click on up on the tool bar.. The normally works for myself..
Posted: Sat Mar 26, 2011 7:26 am
by hellma
Thanks for your help JO-Anne cutting at the mo but will tey this the next time.
Posted: Sat Mar 26, 2011 7:34 am
There is a setting in the SCAL2 Preferences for this (Edit/Preferences/General). There is a drop-down box at the top, click on it and select Inkscape. It is worth looking through all of the Preferences tabs to see what options are available.
Posted: Sun Mar 27, 2011 5:32 am
by hellma
Thanks Heather will give this a try. Just checked preferences in scal and the drop down box I think you are talking about says 90 (inks cape) and the alpha fill was at 70% I have changed this to 100%. away to draw a simple box in inkscape to see if this helps.
Posted: Sun Mar 27, 2011 5:46 am
by hellma
Just tried both suggestion neither are working, thanks for the help anyway.
