Help with AI or Inkscape - joining shapes
Posted: Fri Mar 04, 2011 9:59 pm
by cre8ting
I have a file that I am trying to figure out how to join the shapes in - essentially I am trying to just create the outline -- so not a separate triangle and rectangle but more like a house on its side if that makes sense. Does anyone know how to do this? I keep getting an error message when I try the join function.
Thanks!
Re: Help with AI or Inkscape - joining shapes
Posted: Sat Mar 05, 2011 6:32 am
by jasenj1
The problem with your file is that the diagonal lines are just lines. That is, they are not joined to anything to make a continuous path. When doing this kind of work, the node tools are your friend.
node tools screenshot.jpg (3.93 KiB) Viewed 3300 times
You use them to cut the ends off of bounded areas (rectangles) and attach the end points of separate lines.
It is often better to build objects up from rectangles or polygons, deleting, adding, and moving nodes as needed, rather than using lines.
Another technique is to draw a big rectangle around the entire shape. Then use the paint bucket tool to fill in the surrounding area like this:
paint bucket example.jpg (37.78 KiB) Viewed 3300 times
Then you "Break Apart" the filled in shape and delete the outside frame, leaving just the surrounded shape. But the paint bucket can give inaccurate results.
I've attached a fixed up version of your file I made by deleting lines & attaching endpoints.
Hope this helps.
- Jasen.
Posted: Sat Mar 05, 2011 1:00 pm
by hkvalerio
TFS!
Posted: Sat Mar 05, 2011 1:15 pm
by sstehman
I need to bookmark this topic. Thanks for the explanation.
Posted: Wed Mar 09, 2011 6:32 pm
by cre8ting
Thanks everyone.
Does anyone know of any good tutorials that utilize the node tool to do this?
