Page 1 of 2
Artisan edge cut file needed * added cut file*
Posted: Sat Feb 26, 2011 7:51 pm
by JodyP
Does anybody have a cut file like this...
- Capture.JPG (12.38 KiB) Viewed 5063 times
Re: Artisan edge cut file needed
Posted: Sat Feb 26, 2011 8:15 pm
Jody, did you try to import the image into SCAL yourself? I did it bumping the brightness to 71 to get all the edges to meet.
- Screen shot 2011-02-26 at 8.22.11 PM.png (74.21 KiB) Viewed 5049 times
The trace gives you two images one inside the other but a break apart separates them so you have two. Delete on and your done, or use both one on top of the other
Try it and then if you need help we will be here.
Posted: Sat Feb 26, 2011 8:19 pm
by TheresaTT
Posted: Sun Feb 27, 2011 4:17 am
by janekinso
I tried following your instructions, Susan, and proved to myself that I'm
hopeless at this!
Posted: Sun Feb 27, 2011 7:29 am
Jane,
I'm sorry that it didn't work for you. I wrote those quick instructions for the poster who already had the .jpg file so I didn't start at the beginning.
Where did you get lost or what happened and I'll try again to explain how to trace a .jpg image in SCAL. Maybe one of these videos will help.
http://www.craftedge.com/tutorials/tutorials.php#19
http://www.greatcricut.com/mini-tutoria ... ts-a-lot-2
Posted: Sun Feb 27, 2011 1:04 pm
by janekinso
Thanks, Susan, for reminding me to watch the videos again. I guess it was the ungroup part that I forgot to do. I used the snipping tool to capture that image on the board, and saved it as a jpg. then I went through the steps, but forgot the ungroup part. I'm back home now, and have time to play, so I'll try it again.
Posted: Sun Feb 27, 2011 5:36 pm
by Maggie
For bracket shapes, I have gotten to where I pull up a font, type the four brackets, then rotate them and stack as desired, finishing with "blackout" (no shadow). The cut is usually clean and fast using fonts. I didn't see that someone had already met this need when I posted this, but here's another version. If you want more "curve" to your brackets, simply try another bracket with more bow to it and give this technique a shot.
Posted: Tue Mar 01, 2011 11:46 am
by JodyP
Thanks to everyone. I did do a couple of them, I was just being lazy and was hoping some were aleady done. The idea of using a font bracket is a great one. Will try that too.
Posted: Tue Mar 01, 2011 1:41 pm
by JodyP
So here are my artisan edges with svg file
- Capture.JPG (31.71 KiB) Viewed 4892 times
Re: Artisan edge cut file needed * added cut file*
Posted: Tue Mar 01, 2011 1:53 pm
by hkvalerio
You did a great job JodyP!
