Print a image then cut
Posted: Sat Feb 05, 2011 2:10 pm
by fruity46
Hi I have a question, and I hope it makes sense right can I import a image then print it and put it in my cricut to cut out??
Re: Print a image then cut
Posted: Sat Feb 05, 2011 2:16 pm
by Sweetness4713
If you are speaking about a photo you can only cut the outline of it... If it's a layered image you designed you would need to ungroup it...
Posted: Sat Feb 05, 2011 2:21 pm
by fruity46
Hi yes, do I use the trace tool for this
Sweetness4713 wrote:If you are speaking about a photo you can only cut the outline of it... If it's a layered image you designed you would need to ungroup it...
Posted: Sat Feb 05, 2011 2:25 pm
by gj1
yes. Use the PLACE to bring the picture into scal and the TRACE to get the outline of the same...using the eye turn the layers on and off to print and then cut.
Posted: Sat Feb 05, 2011 2:26 pm
by fruity46
Hi thanks for your answer and fast response
Posted: Sat Feb 05, 2011 3:00 pm
by gj1
http://kandrewdesigns.blogspot.com/2010 ... -sure.html
if you need more info...good tutorial above.
