For some reason, my font screen that pops up in Inkscape isn't small anymore but full screen. If you minimize it's still full screen you just can't see the "apply" button. If you maximize then you can't see the "apply" that's the only difference in the two. It used to just be about 1/4th of the screen. Is there anything I can change to fix this?
Inkscape 0.47, Windows XP, SCAL2
returning viewing to normal
Re: returning viewing to normal
Yah I had this same thing happen.. What I did is open inkscape..clicked on the T at the top of the toolbar for the text box.. then just minimized the inkscape window.. click on the top of the text box which should still be opened up.. pushed it upwards a bit and then clicked on the bottom of that same to make the box smaller a bit.. This should solved your issues.. It worked for me...
Thank you so much! Finally got back to fixing this!
