Sure Cuts a Lot 3.0 for Windows & Macintosh
Re: Sure Cuts a Lot 3.0 for Windows & Macintosh
No. SCAL was sued by Provo Craft over the Cricut's being able to connect to SCAL2 for cutting. This forced SCAL to remove that capability from all future SCAL releases. However, you can use SCAL 3 - 5 for designing cut files and exporting as SVG for Cricut's Design Space which works with the newer Cricuts. Personally, I think it makes more sense to dump Cricut and look at all of the other amazing cutters on the market that WILL cut from SCAl.
Kamaftew
Sure Cuts a Lot 3 0 for Windows Macintosh
Post by Kamaftew »
Thanks a lot for your update. It really helped to resolve my issue also of login through Facebook.
But one small problem, when we login through Facebook, the default language is coming to French. Please let me know how can I change the default language to English when login through Facebook
On your home page in Facebook, scroll down and at the bottom of the left column, you will see several choices for a language. Select English and then in the popup window that opens, select the right side option which, in French will say "Changer de langue" (change language). That's it!
