Iron on Vinyl
Re: Iron on Vinyl
This project is awesome, Todd...they are going to love them!!!!!!
This thread came up for me in SEARCH, as I have got some 12x12 sheets from vinylforcricut....not sure if it is good stuff or not...never used it yet, so I was looking for more directions.
I use an E and only have regular blade and deep cut blade and housing...which should I use?
I was told in directions that came with vinyl to use setting of 3-3-3 to cut, does this sound right?
I will use parchment paper while ironing...should I get a flat edge cookie sheet? I will be using regular iron.
It says in directions, press and hold 6 to 8 seconds and move around about 20 seconds, allow to cool and peel mylar stuff.
I guess it is best to do each color one at a time and not try to put together a puzzle of sorts and iron all at once?
My main question is...should I use steam?
Any help from anyone is appreciated...thank you. Not sure what I am going to make...I have a couple of toddler size tshirts to practice on.
talanhart
Re: Iron on Vinyl
Post by talanhart »
On the vinyl that I have, I set my blade at 3 and my pressure at 3. Remember to cut your image Reverse. I just used my ironing board and no steam. I had to iron my vinyl for 1 minute and 15 seconds per the directions.
Re: Iron on Vinyl
Thanks for the info...appreciate your assistance, as always you are so good to everyone :)
TheresaTT
Re: Iron on Vinyl
Post by TheresaTT »
ok, here is mine. But in all of my searching, i forgot where i got the design. I just love it.!!!! If anyone knows the creator of the design, please share so i can give thanks. I am not that good at saving my files with names. actually, it is just dumb luck that i can find them on my comp. after i get them :oops: :roll:
DSCN0846 [800x600].jpg (85.71 KiB) Viewed 1799 times
Theresa
personalizedbydani
Re: Iron on Vinyl
Post by personalizedbydani »
Theresa,
That is BEAUTIFUL!!!
Re: Iron on Vinyl
VERY WONDERFUL JOB!!!
