Setting Up 2 Parallel Rows Of Words To Be Cut On Vinyl Roll
Wind Gatherer
Re: Setting Up 2 Parallel Rows Of Words To Be Cut On Vinyl R
Post by Wind Gatherer »
more
4 .jpg (90.96 KiB) Viewed 3349 times
Wind Gatherer
more
It appears to me that "HIT" and "THE" are not the same Height. When you select each and look at the H value on the Size & Position panel, are they the same?
Wind Gatherer
SandyMcC wrote:It appears to me that "HIT" and "THE" are not the same Height. When you select each and look at the H value on the Size & Position panel, are they the same?
Is getting quite late here in UK. I'll try to look at this Tuesday and get back to you.
Thanks, once more :)
Wind Gatherer
Yes words are different sizes, see attached. I assume if I change HIt to the same size as THE, the issue will be solved?
Thank you.
S2 .jpg (91.79 KiB) Viewed 3342 times
Since I've never fully understand what the final result/project will be, I can't answer your question. In general, people just type out letters, set the size of the overall text (height or width) to what they need and then cut them out. In your case, it seems you're needing something very specific that I don't fully grasp. Sorry! If you have an example of what you're trying to achieve, feel free to post it and then maybe I can help some more. :)
