If your created the line as a stroke, you can change the stroke style using the edit objects command shown in the screen shot, edit your stroke style to a dash or dot and then select the image and use Path|Stroke to Path to convert your stroke to a vector that can then be cut with SCAL. Note that you may need to increase the width of your stroke to get a decent cut.
Christina “I do that which I cannot do in order that I may learn how to do it.” ~Picasso
