Sky cut and pre printed sheets for print and cut
geekinesis
Post by geekinesis »
Hi,
I am looking into buying a sky cut v series
I understand it uses a camera to find the reg marks for print and cut.
I am used to using illustrator to create my artwork with a rectangle box around it. I then use the corners of the box as my regmarks layer in scal. (Using a silver bullet to cut.)
Can I still use this method with the sky cut? Does the camera recognise the corners of my rectangle?
I still have several thousand printed sheets with a rectangle pre printed on them that I don’t want to throw away.
I know I can add reg marks by printing to pdf from scal and opening the file in illustrator.. but this question is specifically about using a rectangle box that is already printed on a sheet.
