moving jobs in te cut screen
Posted: Thu Jun 20, 2019 6:53 pm
It would be really great to be able to move your text or files around after clicking onto the cut screen and being able to adjust the vinyl width for each color cut. In every other software I have used you are able to do this. I makes placing objects in the correct spot much easier than having to have them placed before clicking the cutter button. This would especially make multi color cuts better so that you could move each new color to the proper position to match the next sheet or roll of vinyl because all sheets or rolls you may use will not be the same size.
