Good evening,
I recently switched to IOS Mac Pro from Windows. I have a GCC plotter Expert 24 that I was using Greatcut with for years. Which SCAL product is the best compatible with IOS and GCC products? I mainly use this for promotional products.
Adam Jeter | The Real Estate Group jeter@treg.com adamjeter.com
Is SCAL Pro 5 compatible with IOS and GCC Expert 24?
Re: Is SCAL Pro 5 compatible with IOS and GCC Expert 24?
SCAL5 and SCAL5 Pro are the versions compatible with your GCC and there is a Mac version which works with previous Mac O/S's and Big Sur.
Thank you very much for your response. I'll check it out.
V/R,
Adam Jeter
V/R,
Adam Jeter
I should have also mentioned that there is a 15 day trial for SCAL and that will allow you to test and make sure that it will meet your needs. It will add watermark cuts into your design but otherwise you can make sure it communicates properly.
