Need help opening .svg.xml files
- Location: Michigan, MAC OS X V10.6.4; Personal Cricut V1.1 and Cricut Expression V2.34; SCAL2 V2.029
I have tried to download several different .svg files from the SCAL forum but can't get them to open up. I have inkscape, corel painter essentials, SCAL 2, and I run a MAC OS X computer. The files download to my download folder as a .svg.xml file. Then when I try to open it, it automatically opens Corel Painter and then gives me a message that the file cannot be opened. I try to import them into Inkscape and I see them in my download file but cannot click on them. If I download from the SVG Cuts website I never have any problems importing them after they are downloaded. Does it have anything to do with the .xml? Is it because I am running a MAC and it was created on a PC? Any suggestions?
Have yourself an incredible day!
Re: Need help opening .svg.xml files
I am pretty sure I read that you have to delete the xml part off the file name just leaving the svg
Scrappin My Way Through
Thank you soooo much!
I re-saved them as a ,svg file instead of .svg.xml and now it works perfectly!!!
Enjoy your day... I know I will mine, especially now that you helped me figure this out.
It's your web browser adding the .xml extension. When you save the svg files make sure that if it doesn't have Scalable Vector Graphic as a file type choice that you choose something like All Files and then change the extension back to .svg. HTH
