SCAL and Inkscape - A marriage made in heaven
AnointedHands
Post by AnointedHands »
Welding is possible when using Inkscape....thanks SJ5. I didn't even know about the program. I had an older version of CorelDraw and was trying to do some things with that and decided that I am going to have to upgrade. Once I found out about Inkscape, downloaded it and love it.
I have attached a file created with Inkscape and SCAL.
HomeSweetHome.svg
(26.9 KiB) Downloaded 527 times
susan
Re: SCAL and Inkscape - A marriage made in heaven
Post by susan »
That is fantastic :D did you create it in coral draw? :roll:
AnointedHands
This was created in Inkscape which is the same type of program as CorelDraw, only freeware. I have version 8 and I could not figure out how to save as .svg using Corel. Inkscape is an excellent program. If you can use CorelDraw, you can use this program.
boysboysboys
Post by boysboysboys »
Is inkscape difficult to use??
Your design is great by the way!!!
AnointedHands
boysboysboys wrote:Is inkscape difficult to use??
I have used CorelDraw for years, so it isn't for me. If you are not familiar with vector-based artwork, it has a STEEP learning curve. However, once you get the hang of it, it is a breeze.
boysboysboys
Hmmmm STEEP learning curve....sounds hard! I may try it anyway!! Wish SCA could weld!
AnointedHands
boysboysboys wrote:Hmmmm STEEP learning curve....sounds hard! I may try it anyway!! Wish SCA could weld!
Here is a post with instruction on how to weld the words together. I welded my words inside another character so it was a bit more complicated cuz I had to so some manipulating...that the steep learning curve part.
Check this post out.
http://forums.surecutsalot.com/viewtopic.php?f=6&t=68
lisa_anderson77
Post by lisa_anderson77 »
I am new to this board so hello everyone! I have downloaded inkscape today and it came with soooooo many files that were unzipped I am having trouble finding the install or setup file. Can someone point me in the right direction.
AnointedHands
lisa_anderson77 wrote:I am new to this board so hello everyone! I have downloaded inkscape today and it came with soooooo many files that were unzipped I am having trouble finding the install or setup file. Can someone point me in the right direction.
when you download the file for the program, I think it gives you the option to "run" or "save". Just choose run and the program will install.
Kate
Post by Kate »
That is really cool! Thanks for the heads up on installing inkscape- I am just downloading it now and I think I will cancel and run insted of save! Thanks!
