Imported images in SCAL - resolution?
Posted: Sat Nov 02, 2019 9:33 am
I tend to draw / design my images in Inkscape then export as .png (either 600dpi or 1000dpi if small images) and then import into SCAL and then print.
However I've noticed that the print quality from SCAL5 (I've got both the Pro and Standard versions) is different on occasions. Sometimes the images are clear and sharp and none-pixelated (as you would expect from an image that originally was a vector and was exported at high dpi) but other times I can definitely see pixelation in there.
I can't find anything on how SCAL deals with imported images in terms of the resolution it deals with. For instance does it reduce everything down to 600dpi? If I export and image from Inkscape and it's oversized so I shrink it down in SCAL and then print it, does this make a difference?
Is it best to export images from Inkscape at the correct size, or export oversized and then shrink down in SCAL? For example I'm designing a lot of small stickers that are often 10mm by 10mm in size (or thereabouts). Should I design and export at this size in Inkscape or export larger and resize in SCAL? Would either approach make a difference / give better results?
I'm just trying to get an understanding on how SCAL handles imported images and the best way to maintain the original high-quality and avoid pixelation when printing.
Thanks in advance!
Thanks in advance!
