Positioning Line Up Squares Accuratly On Cutting Mat
Re: Positioning Line Up Squares Accuratly On Cutting Mat
2 more
- E.jpg (248.11 KiB) Viewed 3538 times
- D.jpg (252.31 KiB) Viewed 3538 times
See my latest post on removing watermark.Thanks.SandyMcC wrote:So sorry! I have different versions of the UM for different cutters and then a version that's JUST SCAL. I should have referenced the just SCAL version number.
I'm not sure what you mean by altered.... but I'll assume this is the issue and solution. After deleting the watermark, marquee-select (drag your mouse) so that you can select both the A and it's interior shape and go to Object>Merge.
Oh, great,yes that works a treat. Thanks.SandyMcC wrote:I'm not sure what you mean by altered.... but I'll assume this is the issue and solution. After deleting the watermark, marquee-select (drag your mouse) so that you can select both the A and it's interior shape and go to Object>Merge.
You're welcome!
In my machine i have a ELAU PMC-2 Servo Positioning Controller
Part no: PMC-2/11/08/000/00/03/00/01/00
But now the Servo Drive is defective. i am unable to find the same part no.
Can anybody help me to find the same part no.
or Can it be replaced with some other available part no?
Does anyone have any experience in this types of Servo?
