Bunny Box
mommyshome
Bunny Box
Post by mommyshome »
Hi. After a post looking for a bunny box I created my own. I have not test cut these so if you try it please add your comments. I did these in Illustrator and then traced into SCAL. I think I see an issue on the last two but I don't know how to fix it. I don't know the program very well.
There are several versions all on one file, the forum only allows 3 attachments so I combined them.
1. Outlines
2. Polka Dots
3. Funky Dots
4. Chevron
5. Pretty
6. Pretty Backwards
It's 5 & 6 that I have some concerns about.
Edit: I think I figured out the issue I was noticing with transferring files from Illustrator to SCAL, or at least the long way around. I was getting two lines instead of one. I went through the bunny top files and removed all of the extra lines from them that I could see. I couldn't find them on the tabbed strip one or one of the bunny designs. This led to a slightly different version of #6 and I now have:
7. Pretty Backwards Version 2
I will delete and reupload the file that I adjusted.
Thanks.
Tabbed Strips.scut2
(40 KiB) Downloaded 623 times
Bunny Box Tops Collection.scut2
(1.05 MiB) Downloaded 634 times
My files are for personal use only. Please do not sell my files or items made from my files. Thanks.
jrichards
Re: Bunny Box
Post by jrichards »
Those are adorable! My problem was that I was unable to figure out the size of the strips (circumference of the bunny). I tried to do it in 2 sections and I probably should have done it in 3. the teeth got too long and then I had trouble gluing. I will give these a try later. Thanks for all of your hard work.
mommyshome
Re: Bunny Box
Does that mean that the tabs are too long? Are they overlapping around the curves? I may be able to get my kids to cut one out for me today so we can give it a test run.
jrichards
Re: Bunny Box
Post by jrichards »
The teeth weren't too long, I tried to adjust the size and made them too long. I wasn't sure how many I needed to go around the bunny.
