Fill is missing
craftedge
Site Admin
Fill is missing
Post by craftedge »
If you have a fill set, but the fill is not showing up, please check the following:
1. Make sure under the View menu that the Show Outlines Only option is not checked.
2. Make sure the fill Opacity is not 0% as that would make the fill completely transparent.
3. Make sure the Workspace Alpha is not 0.
4. By default, the fill will only show up if the path is closed. If you want open paths to be able to have a fill, you can change the behavior in the Preferences.
jrichards
Re: Fill is missing
Post by jrichards »
None of those have anything to do with it as I have checked all of them and they are set correctly.
