svg file not showing up in cutter window
Posted: Wed Nov 12, 2014 6:32 am
by jdh8
I imported a png image in to inkscape and saved it as an svg file. When I import it from my desk top to sure cuts alot pro (3.051) it shows up on the mate fine. When i click the cutter icon it does not show up in the cutter window its like the file just disappears. Any help on what I am doing wrong would be super.
Re: svg file not showing up in cutter window
Posted: Wed Nov 12, 2014 7:04 am
Good Morning,
The file you posted is not an svg it is an image still. Somehow you imported it and didn't "trace" it to convert it from a png to an svg hence you could not open it in ecal through the svg import.
You have two options: You can trace the original png file in scal directly using auto trace image or you can go back to Inkscape and do a path/trace bitmap and then save.
You can tell your file is an image still by looking in the very bottom panel in Inkscape and see it says image.
- Screen Shot 2014-11-12 at 6.41.13 AM.png (29.28 KiB) Viewed 4070 times
Hope this helps if I was unclear about how to, just ask more questions.
Posted: Wed Nov 12, 2014 7:52 am
by jdh8
thanks. Another ? I have is what is the best kind of files to save artwork in to import to the scal ?
Posted: Wed Nov 12, 2014 8:05 am
jpg or png is what I use when not using svg. I usually try to import/trace directly into ecal and if the artwork is too messy I go to Inkscape/trace and clean up and save as svg and import the svg to ecal. All depends on the complexity of the image.
Posted: Wed Nov 12, 2014 8:33 am
by jdh8
thanks so much for your help
Darryl
