need help with cross design
Posted: Thu Dec 12, 2013 2:02 am
by blairbsb
Trying to combine heat transfer glitter vinyl and machine embroidery 3 letter monogram on a t-shirt for daughter. I am looking for a svg file of a chevron filled cross that will be only the chevron design in a cross shape cut from heat press vinyl (so when pressed, the t-shirt will show thru) and with a large enough center circle cut out of the cross for 3 or 4 inch font monogram KK to be machine embroidery. Hope this makes sense. Can anyone help me?
Re: need help with cross design
Posted: Fri Dec 13, 2013 8:12 am
Is this the idea? If so then I can finish it up and post it. I cut the cross with the chevron pattern out separate from the circle. If you want the circle cut as part of the cross I'll give it a try but didn't want to spend too much more time until I check with you.
