Help Stencil for wine glass
Soulsisterd
Location: PC Widows Vista, Circut, SCAL 2.044, Inkscape 47
Post by Soulsisterd »
Hello Ladies. It's ben a whie since I have been on. I pray that all is well with everyone.
I need some help. I am trying create a stencil for a wine glass that is 7 1/2'' tall, rim 3 1/2'' wide, base is 3''. I would like o learn how to create designs with curved surfaces.
I am goin to try my hand at painting. I anyone has any pointers on painting on glass with acrylic paint, pleae share.
I understand I can use a makeup sponge to dab on the paint for a smooth finish
Thanks a bunch
Blessings SoulSisterD
talanhart
Re: Help Stencil for wine glass
Post by talanhart »
When I cut stencils for glasses that have a contour, I use the Envelope distort feature in Illustrator. I'm not sure what it's called in Inkscape. Depending on the glasses angle, I use an angle of 8 or 9% and then I print on paper first to see how well it's going to look on the glass. The last glasses I did were at a 9% warp and when I wrapped the stencil around the glass, the text was straight across. The picture is a sample of the artwork and then the artwork warped at 9%.
grabb.tiff
grabb.tiff (13.21 KiB) Viewed 8601 times
Soulsisterd
I am that great a Inskcape, and did't see anything close. Could be simply be have no clue what I am looking for. :lol:
Here is the file I m trying to format.
wedding dress.svg
(7.42 KiB) Downloaded 457 times
Thanks a bunch
talanhart
Post by talanhart »
Here is the artwork at 9%. Will this work?
wedding%20dress.svg
(10.87 KiB) Downloaded 513 times
Soulsisterd
Sorry Todd I download the wrong file.
Here is the correct file.
Thank You for you help.
One day if you don't mind would you will me through how you did it or maybe send me the instructions on how to do it.
The real deal.scut3
(60.02 KiB) Downloaded 454 times
Thanks a bunch
Inkscape does have a version of envelope distort, though it is a bit different from AI's. You can find it in either the Path Effect editor (Path menu) or Extensions/Modify Path. I'm not that familiar with it, so you should look up some tutorials on how to use it.
Todd, what settings did you use? I couldn't figure out which shape you used in AI.
talanhart
Post by talanhart »
Envelope distort>Make with Warp and I use the Arc at various percentages depending on the glass.
warp.tiff
warp.tiff (41.52 KiB) Viewed 8545 times
Soulsisterd
Good morning. I was able to find the Envelope Deformation. However I could not locate the Warp options in Inkscape.
Could you tell me where I can locate those options? If the manual have a search options it would make things so much easier.
Thank you everyon for ALL your help.
Thanks a bunch
talanhart
Post by talanhart »
Post your file as an SVG and I will put the arc in it for you. I can't use the SCUT file on this computer.
Soulsisterd, Envelope/Warp that Todd is talking about is in Illustrator. Inkscape just has Envelope Distort (at least in 0.47) and then you would use the node option to adjust your file. Not sure what has been added to 0.48. I've attached your file with a 9% warp.
Todd, Thanks! I think I was using backwards reasoning. I should have been thinking like a cupcake wrapper. ;)
The real deal warp.svg
(4.21 KiB) Downloaded 502 times
