Problem since update
Posted: Wed Mar 20, 2013 5:29 am
by has2tri
I have just done the update and since I did I can't cut anything.
I use an Ecutter and everything loads up fine then when I press the cut button it gets stuck on checking firmware
Anyone know of a solution to this?
Shell
Re: Problem since update
Posted: Wed Mar 20, 2013 5:57 am
Do you have the "b" version of the update or the first version? If you have the first version try downloading the newest update. If that doesn't fix your problem then re-install the last version that worked for you. HTH
