aligning images
Posted: Thu Oct 25, 2012 8:50 am
by Tam
Ok someone help me out here. I have searched the forum but not finding what I am looking for. I want to aline some items on my mat but right now I am clueless as to how to do u. Can someone one help me.
Re: aligning images
Posted: Thu Oct 25, 2012 11:19 am
by mommyshome
I'm not sure what kind of alignment you are meaning. Do you have a pic?
Re: aligning images
Posted: Thu Oct 25, 2012 12:18 pm
See this post, sounds like the same question, sorta.
viewtopic.php?f=6&t=29524
Re: aligning images
Posted: Fri Oct 26, 2012 11:03 am
by Tam
That is sort of what I am talking about but u don't tell me how to achieve that.
Re: aligning images
Posted: Fri Oct 26, 2012 11:23 am
by Tam
this is what I want to do. I want to take that little half circle and go all the way around that oval then weld so I can cut several.
Re: aligning images
Posted: Sat Oct 27, 2012 8:19 am
TAM,
What you want is object on path in SCAL/eCAL and I don't know how to do it in SCAL/ecal. Perhaps if you change the title of your post someone might be able to help you. Scallop on circle or something like that.
I can do it in Inkscape pretty easily so if you are in a hurry I can post it for you.
Screen shot 2012-10-27 at 9.19.53 AM.png (18.37 KiB) Viewed 4972 times
Re: aligning images
Posted: Sat Oct 27, 2012 8:49 am
by pastda3
I don't use eCal, but I found this instruction PDF and just took a quick glance at it. Does eCal have the ability to do what you want easily? I also use Inkscape to design the majority of my files. Sorry I can't be of any help. I just thought the following manual might be helpful for future use.
http://www.craftedge.com/products/eCAL%20Help.pdf
Re: aligning images
Posted: Sat Oct 27, 2012 9:16 am
I think with some work and luck you can use the Rhinestone feature but there is a lot of guess work as to stone size. Another way is to find an oval shape on a font and use the type text on path feature but I haven't found one yet.
Re: aligning images
Posted: Mon Oct 29, 2012 3:33 am
by Tam
Sue thank so much for trying to help. I ended up making it in MTC and saved it as an svg file. There are a lot of things missing in Scal that is simple things like alignment and duplicate around something. Seems to me it would be an easy fix.
