Print and Cut does not work!
Posted: Tue Oct 16, 2012 12:21 pm
by Omily
I am trying to do a Print and Cut project but it does not work.
For one, SCAL does not remember the correct calibrated values, so I have to put those in every time I open the program over again. But this is not that big of a deal.
My biggest problem is that it gets cut wrongly. It is off by 1mm, which is too much on a detailed file like mine.
How do I solve this?
Since P&C does not work, I tried using Origin Point method in cutting. I put the blade in the bottom right hand corner of image to be cut and made that the origin point. I pressed 'cut' and it cut off again! This time by about 1,5 cm.
I have a 13inch Black Cat Cougar.
Thanks so much for any help!
Re: Print and Cut does not work!
Posted: Wed Oct 17, 2012 10:23 am
Hi, consider contacting CraftEdge support about calibrating your machine and how to ensure that the seiitins are saved.
You can find the link along with FAQ's at:
http://CraftEdge.com
Posted: Wed Oct 17, 2012 1:52 pm
by newbiecat
Hi there
Have you calibrated your machine ? did you manage to set it to cut correctly ?
Try entering the numbers then close out of the program using File/quit rather than any other method and see if that solves the problem of the numbers not working
good luck
