Christmas Card Tree Fold & Tuck
I'm looking for some help making a fold and tuck tree.
Card file in post below.
Louise-Paisley
Re: Christmas Card Tree Fold & Tuck
Post by Louise-Paisley »
I will have a play later if I get time, quite busy just now.
Might I add that these type of folded weave or whatever it is called things often look better with a double sided card, maybe use a plain white and print each side with a different colour or digital texture or even glue two thinner contrasting cards together. Then the parts folded down have some contrast with the base colour if you see what I mean.
Louise-Paisley
OK, Try this one..
I widened the diamonds and they should now tuck in correctly behind the next one down..
xmas-fold-tree.scut3
(36.76 KiB) Downloaded 428 times
SOOOOO much more PERFECT!!! Thanks for doing this for me!!!
I did use the second one and the score lines help so much!
Louise-Paisley
Nearly everything I cut that has folds I put fold lines in and 'cut' them with the embossing tool, the cutter does a better job than me and much faster when you have quite a few folds.
Soraya
Post by Soraya »
I want to thank you for sharing this file!
