Lettering Delights Graphics-PNC
Posted: Sun Jan 22, 2012 1:18 am
by StampaLady
I would like to do a print and cut of a LD graphics, Eskimo Kisses, but when I tried Trace Image, eCal kept crashing. When I do Place Image, I kept getting a square line around the image. I can't ungroup the grapics but can click Break apart but it does nothing. I also tried re-sizing the graphics, eCal still crashes when I do the Trace Image. If I can't do a Trace Image, how can you delete the square line around the image?
Re: Lettering Delights Graphics-PNC
Posted: Sun Jan 22, 2012 4:15 am
by gj1
If you print your Placed image from the software, the square outline won't print unless it is part of the original picture.
Posted: Sun Jan 22, 2012 7:26 am
There are a bunch of videos on how to pnc lettering delights images you purchased.
See this post for links to them and advice.
viewtopic.php?f=18&t=26895&p=102806&hil ... ts#p102806
Posted: Mon Jan 23, 2012 11:27 am
by alliellis
How do you get it to just cut the outline and not all the lines. The Lettering Delights Graphics don't come layered. I have looked at some of the tutorialls but they seem to bring the image in in black and white. Do ypu fill the colours in in ecal?
Any help appreciated
Posted: Mon Jan 23, 2012 12:04 pm
Allie, svg cuts did a video just for P2C for eclips with Lettering Delights files.
http://www.youtube.com/watch?v=D-OLSrFf ... re=mh_lolz
As far as I know this is the only one specifically for eclips/svg files. The trick is to designate the "print" file as a "draw" and then when you go to
cut you just
skip draw in the instructions
Posted: Thu Feb 16, 2012 1:55 pm
by melchache
how i do it is,get your image and place it where you want it ,then do copy and paste in place(this will place the copy exactly on top of the original),then go to path and union,this will make a shadow of the original.then go to layers and hide the shadow,print the original,when you have done this you will need to hide the original and show the shadow.then just cut the shadow
