Lib It up shutting unexpectedly
sblackford
Post by sblackford »
I just downloaded Lib It Up 2 and have been adding svg's to my libraries. It lets me add some and then it crashes. It's done it several times since I loaded it an hour ago. Thoughts?
Re: Lib It up shutting unexpectedly
You might want to contact support for the specifics regarding this problem...but I will just mention how I create my own sort of library using a memory stick, creating folders there and saving the file AND a picture of the file, either one that is provided by the files creator or a snip of the image taken while open in scal...using the same name for both...this way when opening the file there is a visual of what the files are.
I was concerned with the Lib It up, that it would take up too much memory on my computer and slow things down, so I have not used it. If I did it would just maybe be for a few things that I used all the time.
Hope you get the help you need for this.
