Can someone explain these two things to me? What they mean, how to use them properly, etc.? I've searched and searched and can't really find what I'm looking for.
I bought a new Pazzles on Friday and have wasted so much vinyl trying to cut properly. My cuts aren't completing - leaving a little tab of vinyl attached to what I need to weed away. It looks very sloopy!
After a little searching, I think I've found that these 2 settings can help with this, but I'm not really sure what to set them to.
I could definitely use some help from some vinyl cutting (and/or Pazzles) experts!!
Thanks in advance!!
Overcut and Offset
Re: Overcut and Offset
What I see is that with text the one raises & lowers the text and the other makes it larger or smaller. I know that when you type on path in a circle the one that raises and lowers is sometimes what is need to make the text look right and the size helps it fit the circle better as needed.
Something makes me think that if you export the .svg for a new one from scal it might solve the problem...
BTT though for someone who really knows the scoop on this.
Here is what I remember seeing in the past the forum but this on the wishlist for the software: (I searched for overcut)
viewtopic.php?f=8&t=19142&p=82948&hilit=overcut#p82948
The overcut feature equals blade offset.... so I would think you may need to tweek a bit with your machine.
I do not know what offset is in the scal software, but Offset in inkscape means you parallel your shape.
I too have been having problems with my shapes not completing. I just opened my pazzles and have been testing it with my Mac and SCAL for the last 30 mins, using copy paper, and nothing will complete a cut properly.
Did anyone find a solution for this? It's kind of useless without making decent cuts...
