curve text on the bottom of a circle
Posted: Mon Jul 25, 2011 4:37 pm
by sharloww
I hope you guys can help... I am trying to curve text on the bottom of a circle... I am pretty familiar with Inkscape and know how to work the text on a circle. I even broke a circle apart, but when I tried to put the text on the bottom part of the circle it was backwards... I can't figure out how to get the text from left to right. Sorry any tuturials avaliable?
I am trying to curve text on the bottom of a wreath... similar to this
Re: curve text on the bottom of a circle
Posted: Mon Jul 25, 2011 4:59 pm
by Sweetness4713
If you have SCAL2 .. you can do that right in there.. here is a video to show you how..
http://cleversomeday.wordpress.com/2010 ... t-on-path/
Posted: Wed Jul 27, 2011 7:12 pm
by firstcut
Normally, the way you do this in Inkscape is by reversing the path of the circle (Path>Reverse Path) before you place the text on the path (Text>Put on Path). If that isn't working, try starting over in a new document.
Posted: Thu Jul 28, 2011 9:40 am
by sharloww
First cut.. that worked... everything else has not worked... the letters were uneven or not correctly spaced..and how simple is that! Thanks a ton
Posted: Wed Oct 26, 2011 10:37 am
by lucrocs2001
Probably a stupid question on my part but I am going to ask anyway....so this cuts out words/letters correct? What if you just wanted to print it out on an image?
Posted: Wed Oct 26, 2011 5:54 pm
by firstcut
No stupid questions here. Though SCAL's primary purpose is diecutting, either Inkscape or SCAL can be used for printing. I use Inkscape for a lot of print projects.
