HELP How to size dingbat?
NancyE
Post by NancyE »
Would someone tell me if it is possible to resize a dingbat in SCAL?
I cannot seem to figure it out. I have tried highlighted and dragging the arrows to no avail. :roll:
Nancy
wreed06
Re: HELP How to size dingbat?
Post by wreed06 »
Use the drag handle - it has a cross with an arrow on each line - only 2 arrows, not the 4 arrows. Pictures are below.
This is the arrow handle to drag.
This is what it looks like after dragging.
NancyE
Post by NancyE »
Thanks!
That won't work for me yesterday. For some reason the dingbats were solid black and wouldn't resize. Must have been a computer glitch.
I really appreciate the time you took to answer. ;)
wreed06
Post by wreed06 »
Strange they didn't work yesterday. Try them again now and see if they work. You can also resize them by entering the width and height measurements manually in the Properties box. You could try that. HTH
Maggie
Post by Maggie »
Sometimes if you rotate the image, it's makes things difficult on resizing--the rotate tools rotate as well rather than staying where you can drag the image. You might try resizing before rotating when possible, or starting over with a fresh image...seems to work for me when things get to that point.
