Paintcan - nice quality
Posted: Sun Sep 21, 2008 9:14 am
The paint can has lots of layers. I separated everything - you choose what to cut. The ridges on the can will cut each on separately. You can cut them, or draw them after assembly. I kept the shadows in the SVG and colored them green so you can see them. There is a thin small highlight on the brush that I kept with the brush pieces. I think I colored it red so you can see it. You may want to re-arrange pieces to cut like colors together. Of course you can change the color of paint as desired!
P.S. Be sure to arch the Paint letters to help make the can look round.
NOTE: The SVG file needs more tweaking, so I've removed it just now. Will post when it is fixed up. If you need a paint can / brush, this is a great graphic!
