Page 1 of 2
problem with shadowing some fonts
Posted: Wed May 18, 2011 4:24 pm
by shawnamy501
I updated my SCAL2 to version 2.043 a couple of weeks ago and ever since then I'm not able to use the shadow on some fonts, such as Scriptina and Aquarelle. I pulled up a file that I had cut in the previous version, and it now looks like this. Anyone have any ideas why it's doing this? I really need to cut Aquarelle with a shadow for a gift I'm making soon.
Re: problem with shadowing some fonts
Posted: Wed May 18, 2011 4:33 pm
by gj1
I think maybe you did something with ungroup. Try just typing and spacing all in one operation and then do the shadow and don't ungroup or breakapart. Not sure...I don't have that font to test it.
Posted: Wed May 18, 2011 4:53 pm
by shawnamy501
I didn't ungroup it or break apart. I've tried this multiple times, starting fresh, typing a word, and when I change the shadow it does this.
Posted: Wed May 18, 2011 4:57 pm
by gj1
maybe it is the font...because I tried with basic ariel and segoe script and another and it worked fine. I just don't have that font. Not sure what to say.
Posted: Wed May 18, 2011 5:00 pm
by gj1
I know...post the words just typed and put up the file of the words just typed normal and I will see if I can make a shadow for you. How big do you want it and do you want it all blackout...no holes in the shadow?
Posted: Wed May 18, 2011 5:06 pm
That font won't shadow in SCAL2 for me either. Here is a work-around that you can use:
Place a small shape anywhere inside the text, making sure that it is completely within the cutlines (I used the tiny green circle below).
Select the text and the shape and use Path/Union.
You will be able to shadow the words after using Path/Union.
Posted: Wed May 18, 2011 5:09 pm
by shawnamy501
Thanks Heather, I will give it a try.
gj1 - I don't think it's the font because the shadow feature worked fine on the font before I updated to 2.043.
Posted: Wed May 18, 2011 5:12 pm
by gj1
WOW is that amazing Heather...you are a brain genius person! Once again...thanks for the lessons!
Posted: Fri May 20, 2011 11:54 pm
by hkvalerio
I have run into this same problem with a couple of svg files. What great advice Heather... I never thought of that. Thanks.
Posted: Wed Aug 24, 2011 1:42 pm
by jfm722
Heather, I just wanted to take the time to thank you for this fix. I have often run into this problem and didn't know there was a work around. You have really made my day!
Jen
