Silhouettes
Silhouettes
Does anyone know how to make silhouettes? I'm looking to create something like stain glass lines. I know Susan Blue Robot has done this, but I didn't see a tutorial for doing it. Can anyone help?
Candace
currently using SCAL2, but have SCAL3
I have an Expression and a Gazelle
On a laptop with XP Professional
Re: Silhouettes
In SCAL, you would make a Blackout of the image.
In INK, to make a silhouette of a traced image
1) Open and trace the image (it doesn't matter if it is a detailed trace)
2) Close the trace box
3) Delete the original image
4) Select the trace, then Path>Break Apart (your image should change to black)
5) Deselect the image and then select the largest of the boxes (which will be the silhouette) and move
6) You can then delete the other parts
- Picture1.png (25.88 KiB) Viewed 3061 times
Re: Silhouettes
AnointedHands,
Thank you so much for your post. I actually found out that the kind of image I wanted to create was part of a font called edges on Susan Blue Robot's site. Thanks for your help though.
Candace
Candace
Candace
