Help with converting to SVG
Posted: Tue Nov 02, 2010 11:09 am
by digitaldane
Need help with these two items. I desperately need a svg of these two files. I thought there may be a font but I searched and found out they are logo's and I can't find a font comparable to either of them. Can someone fix these for me so they are in svg format? I would greatly appreciate your help.
Re: Help with converting to SVG
Posted: Tue Nov 02, 2010 12:30 pm
The images aren't showing for me. Maybe try uploading again. If you found them online, just paste the link into your reply, highlight it, then click the Img button above the text box.
Posted: Tue Nov 02, 2010 2:00 pm
here is Gibsun for you. I didn't know whether you wanted a negative or a positive, so I did the positive. If you want the negative just move the word onto the mat provided and cut.
Gibsun.svg
(6.74 KiB) Downloaded 151 times
Posted: Tue Nov 02, 2010 2:10 pm
by digitaldane
Thank you so much!
Posted: Tue Nov 02, 2010 4:30 pm
Here is the other one. For some reason I had to right click and select Open image to see your images.
Posted: Wed Nov 03, 2010 10:58 am
by digitaldane
HeatherM wrote:Here is the other one. For some reason I had to right click and select Open image to see your images.
Thank you so much. I had found one for Martin and cut it with vinyl and put it up already but I am not happy with it. I just cut this one and its picture perfect. Just need to peel the other one off and put this one up.....thank you again!
