Lotas
Posted: Tue May 06, 2008 9:21 pm
by wreed06
Lotas
Notes: Each petal is a separate piece and appears not to have any clear layers. Elegant flower.
Sunflower
Notes: Really neat sunflower scene. Detailed. Suggestion to use brown velum as the top layer of flower center. Use white or silver/gray velum for clouds. (If Cricut cuts velum nicely?). This one requires some time and patience, end result will be fabulous!
Re: Lotas
Posted: Thu Jun 18, 2009 1:39 pm
by iluvshinythings
I tried to import this into SCAL and I get an error message that says that SCAL must shut down. Help!
Re: Lotas
Posted: Thu Jun 18, 2009 1:48 pm
The lotus flower needs to be ungrouped in Inkscape. The stem also needs to be selected, then Path/Stroke to path. It should work OK after you do that. HTH
Re: Lotas
Posted: Thu Aug 20, 2009 11:40 am
by coocoo4cricut
wreed06
Thank you for the lotus flower I love all things asian.
Thanks for your genius HeatherM is there anything you can't do :D
