Lines Within a SVG File
cbrown
Post by cbrown »
I'm trying to design an invitation. I want to put lines that I want cut along the fold line, but I don't want it to cut out completely. The lines are similar to pop up cut lines. I don't want it to be removable, I just want it to stand up when folded.
Candace
currently using SCAL2, but have SCAL3
I have an Expression and a Gazelle
On a laptop with XP Professional
Sheila
Re: Lines Within a SVG File
Post by Sheila »
If I am understanding you correctly, you want to make disconnected lines that you can cut within your paper, without something dropping out.
Click on the draw tool, (one that looks like a pen). Click and release, then drag your line to the length desired and click once to end the line, then hit enter on your keyboard.
AnointedHands
Post by AnointedHands »
I think I understand what you want but I am not sure you can do it with the Cricut. I have only made two pop-up cards and I had to use 2 sheets of paper (one for the inside (pop-up) and one sheet for the outside.
Althea
cbrown
Post by cbrown »
I've created a file in Corel Draw and it looks the way I want. But when I bring the file into SCAL and click on preview, the disconnected line is connect to another line that I did not make to make a closed path. I want to keep that path open. I'll try a dotted line and see what happens.
Candace
You can do this in scal by just drawing the 2 lines in the box which will represent the card... just draw the two side lines but not the top and bottom... Here is an example.. so the two lines will cut there but there is nothing to cut at the top or bottom..
Reddy
Post by Reddy »
What I did was make a very, very thin box for the lines - I had the same thing happen so I connected it with a second line almost on top of the first (I hope that makes sense)
cbrown
Post by cbrown »
Thank you everyone that posted a reply. Within Corel I converted my unattached line to a an object and then combine the overall frame and unattached line. It works. And magically today the other file I make is now showing up correctly.
Here is what I was trying to accomplish.
10 Ibi Invite Outline.svg
(3.6 KiB) Downloaded 176 times
Sorry I don't know how to put the file in the post.
Candace
