Rotating objects
Posted: Sat Apr 10, 2010 3:15 pm
by annell
Could anyone tell me if there's an option to rotate objects to a specific degree? I know there's the 90 degree rotation button. But I want to rotate to 45. Any help is appreciated.
Re: Rotating objects
Posted: Sat Apr 10, 2010 3:33 pm
by Sweetness4713
SCAL2 rotates with the rotation button at 45 degrees...at a time...
Posted: Sat Apr 10, 2010 3:34 pm
by annell
I'm still using version 1
Posted: Sat Apr 10, 2010 3:56 pm
Select your object, then in the Properties window there is a box for you to enter the angle of rotation. HTH
SCAL1 rotate.PNG (26.33 KiB) Viewed 3867 times
Posted: Sat Apr 10, 2010 4:31 pm
by annell
Heather it's actually Ink I am working in to create the file.
Posted: Sat Apr 10, 2010 4:38 pm
Sorry, I didn't even look at the post location, just saw that you were using SCAL1. :oops: You can either double click on your object to get the rotation arrow, then hold down the control key while rotating through three snaps, or you can go through the menu and use Object/Transform to get the Transform dialog where you can click on the Rotate tab and enter the degrees.
Ink rotate.PNG (11.78 KiB) Viewed 3862 times
Posted: Sat Apr 10, 2010 5:04 pm
by annell
Great, got it thanks!
