Fleur de Lis Outline
jcsavoie
Post by jcsavoie »
Here is a fleur de lis that I am trying to get an outline of but for the life of me, I can't figure it out!! Is there a way to do it with SCAL?
Fleur de lis.svg
(1.37 KiB) Downloaded 180 times
doubleup
Re: Fleur de Lis Outline
Post by doubleup »
Is this what you're looking for?
Fleur de lis-outline.svg
(3.3 KiB) Downloaded 184 times
jcsavoie
Post by jcsavoie »
I just tried to open it and it is still filled..I would like it to be an open fleur de lis so that when I place it on my tile, you can see the color of the tile in the middle. Does that make sense? Or like a stencil? I am new to all of this and it is showing..sorry!
talanhart
Post by talanhart »
Is this what you want?
jcsavoie
Post by jcsavoie »
YES!!! Thanks so much Todd! You are a lifesaver!!! What program did you use to do this?
talanhart
Post by talanhart »
I use Illustrator. You might want to download the file again. I noticed the first one had some wonky edges. The second one is better.
lkc
Post by lkc »
If you're wanting an outline only you could copy and paste the image in scal and overlay the two images and select Shadow on one of them(I like it set at 2) and that would give you an outline, too.
Laura
jcsavoie
Post by jcsavoie »
Thanks again Todd! Thanks Laura! I have SCAL2 and it makes a weird shadow around it...maybe I am doing something wrong!!
Right now you have a choice between a squared off corner or a round corner. In the Preferences menu, the Default shadowing gives the squared off corners. De-select that to have the rounded corners. HTH
jcsavoie
Post by jcsavoie »
Thanks Heather!
